SignUp Now!If i have a scan tool what code can i aspect of seing?
I might sound stupid but what hose to the y??? I am new to turbo buicks and dont know much i have to say it has a ta-49 turbo on it if that changes anything!touch the three hoses that run from the turbo to the "Y" and runs to the vavle cover and wastegate.... If your fingers turn black as coal, replace the hoses. (make sure to keep the "Y" oriented in the same direction.
Stay out of the throttle until you get some data logging capabilities. [Or, the next item may be an engine.]No scantool looking for one now!
The wires are msd 9.5 wires its just that there dirty!Stay out of the throttle until you get some data logging capabilities. [Or, the next item may be an engine.]
Just got the car?? Ok, so, how is it equipped? Did the PO provide details of what, if any, mods have been done?
"Well the wires are just dirty cause they are msd 8.5 wires" Huh?
As mentioned, there are lots of checks to be made, B4 data logging.
Spring cleaning, oil, fuel, air filters changed. MAF cleaned.
Fuel psi checked.
Exh system for leaks.
Its got 3 inch down pipe ta-49 turbo 50 pound injectors k&n filter hooker exhaust system but i dont know if engine was ever rebuilt or if it has a cam! And no i am not driving hard i even brought down the boost to the minimum to 14 psi until i get this problem solved and i get a scan tool !
