problem
Russell Stover
I took off this morning from a light and when I reached about 5 pounds of boost it popped and now the car is sputtering when I accelorate. What should I check first?
DO a once around in the engine compartment. Pay peticular attention to air paths from turbo to throttle body. then check vacume lines.
Check your wastegate solenoid vacuum lines, intercooler hoses again....does it run o.k. without boost??
possibly the ignition coil. can be checked with a scope. most
shops should have one.
O.K.then if it runs poor at idle as well with boost then check plug wires and plugs next. Does it set a code?Maybe a plud wire popped loose.
Well it was the ic hose. It popped off just a little bit and I couldn't tell until I really got into it. Thanks guys for all the info
hey dude, my car did this just yesterday its the cam sensor i garrantee that it came loose, you got all the symtoms that i had, i had a friend fix itso i dont know exactly were its at, but in the front of the engine and down a ways, hope i helped
