alright, after all the transmission troubles i've had i take my girl to the track and spend the whole day running 13.28's at best with one 12.96 pass. my biggest problem was spoolup on the line, i couldn't get more than 5lbs and it came up sloooooooooow. this all started when i put the 110 in there, that's all i did and no changes and she started acting stupid. i remember one run going down the track after turning up the wick ( 23-24 lbs ) and i launch ( flashes 23-24lbs ), i'm going down the track looking at the boost gauge and it's going 23,20,19,17,15,14.
, 14 friggin' pounds at the end of the track, and when i backed out of it instead of turbo chatter i heard a big rush of air. i knew what that meant, i had a loose connection in my intercooler piping somewhere. i hunted for that, but nothing turned up. i'll try to pull the piping off this weekend and check everything. could the intercooler be leaking too.
now, on the way home i put in some 94 and the car ran a little better. i tried to do a break stand last night and got the same results ( 5lbs ) and it will not break the tires. that 5lbs is with my foot to the floor. could a header crack worsen at the track, bmason believes i have a header crack that is causing the car to act funny.
i'm running 17-18lbs right now on 94 and my 02's are super rich at 832 mV.
any insight would be greatly appreciated. thanks, beforehand.
