pro-pain, 7-10lbs boost = ?? hp..Viper help
Hi guys, I am looking at doing a propane/nitrous (maybe propain) kit on a 1996 Viper. It is supercharged with an Autorotor nonintercooled screw blower (like Kennebell). I will need to come up with a starting nitrous jet size. I understand that with the Propain kit you can increase boost about 7-10 psi and add a little timing. Does anyone know how much hp 7-10 lbs of boost equals on a GN ? Please specify flywheel or rwhp increase. As in ....if you are using a Propain kit, what size jet are you using to raise boost "how much" and have you dynoed to see the hp increase in that boost ? That is one way I have come up with to ball park a n02 jet size......comparing hp of 7-10psi and relating that to a hp/n02 jet. Another more technical way would be to somehow use a formula similar to a nitrous lbs/fuel lbs ratio like is used to do nitrous tuning.
