Turbo-Rich
ALBATROSS
- May 25, 2001
Anyone have any thoughts on using propane gas on a carb'd TR
It's rated @ 98 octane, burns REAL clean in the engine & is a lot colder of a fuel than gasoline. Not to mention it's pressurized & doesn't require a fuel pump.
I grew up working for a mechanic that used it on most of his vehicles & he was head mech. over a school bus garage. All the busses (350 Cheb's w/q-jets mostly) ran on propane too so I was around it quite a bit. I must say that I was most impressed with how clean it burned. When we rebuilt an engine that had ran most of it's life on propane it looked as clean as a new engine inside. Almost no carbon build up at all. Usually the engines would just plain wear out it's tolorences after many years & many miles(usually over 200,000).
I'm thinking with it being cooler & higher octane that we could run more boost w/less knock easier than with gasoline.
I'm not sure how it would act w/our cars ECM's tho?
Any idea's or thoughts? I'm just being hypothetical really, tho I can easily get my hands on the stuff to add the propane.
I do know that some states have laws against pass. cars running propane but that's besides the point.
I would also think that since our cars are draw-thru & tend to coke up in the turbo the propane would keep things nice & fresh. On Tonyas 83 T the turbo was so coked up when we first got it we thought it was going to be toast. Sometimes it would spool & sometimes it wouldn't. After a good soaking & cleaning it turned out to in good shape.
For anyone who's not familiar w/how to run propane, it's basically just a propane tank w/a hose run straight to a bonnet that fits on top of the carb & an on/off switch somewhere in the lenth of hose for switching back & forth from gas to propane. The carb's butterfies control the amount of propane that enters the motor. It's real simple!
What do you guys think
