- May 27, 2001
Clean the hose and pipe up real good with mineral spirits, brake cleaner, etc, get a can of cheap hair spray, spray the pipe, speay the inside of the hose, clamp the sh!t out of it.
SignUp Now!Originally posted by BoostedBug
If it spits the rods out so be it. Then it will be time to get my Cotton motor. Either way I am going to be happy!
Originally posted by Hyper
At what boost do you get to see your rods? I think 26 olbs which is 100% more than factory will show you what the 3.8 looks like inside soon. Now I am talking about a stock block with no girtal(sp). I am just sitting here watching and waiting on the first to spit the rods out. 22 psi good and safe 26 psi pushing it.![]()
Vader...
I talked with Joe Lubrant about your little problem. He said with the voluum of air that is going through your motor with that set up is like 4 more lbs of boost. So in a since you are getting the same as myself.
Talks to ya...If you look under chip's forum and see the post Chip Guru's help you can read his reply.
I have been using Jay setup for a monthe now. I have been as high as 26psi with only a .5 knock. Then I went into blowing IC hoses off and have since backed it back down to 22 psi on 93 octane. I get zero knock. even locking the convertor up in high gear. I run a Lubrant 22psi chip and 22 degrees of timing for my 93 octane.
finally began tuning my Pro-Pain kit today! After 4 0-80mph runs i am able to run 20 psi of boost now with no knock. thats 5psi more than i could run previously on pump gas. The only thing that is limiting me from running more is the lack of a heavy duty actuator (hopefully it will arrive tomorrow) and a bottle warmer.
Originally posted by TType84
i am not jay but..
nearly no one who has the propane kit has reached a level where they are getting unacceptable knock.
I have not read ONE PERSON say "well... i hit the limit today.. 30psi.. got 5* knock"
every single person whos said anything seems to have said they are over 25psi and blowing off IC hoses, one guy is at 30psi or something, no knock problems.
basically there is no point to run alky and propane... if you already have alky, sell it and that'll take some of the cost of the propane kit off..
two examples of what i mean:
propane alone is more than enough
Originally posted by JayC
It might be an even shorter wait than you think.
Originally posted by emrys
If people are using intercoolers, then then air temp is still a concern. Often times, you can use Alc/H2O injection in place of an intercooler. If I were to do so, I wouldn't have to worrie about blowing off an intercooler hose.
8o )
