Proper vacuum block pic request
84sithlord
Hey guys! I think my vacuum block may be set up wrong... could one of you send pics with hoses attached (with waste gate) and without hoses? :confused:
Does anyone have a photogragh of their set up? I have a similar diagram on my radiator shroud but i'm not sure i'm reading it correctly! Thank you!
all the schematics are helping. i know mine isn't set up like the schematics. are the hose connections interchangable? does it matter what sequence so long as they are all connected to a point on the block? I was actually looking for photographs of other members vacuum block set ups. photographs with hoses attached to the vacuum block and photographs without hoses hooked up to block. thanks!!!
well i saw one on kirban's website so i am starting to think it does make a difference on where the lines are hooked up.
Route your hoses to match the schematics and diagrams....It DOES make a difference which ports each hose is hooked to. HTH ---Keith
