Factory bolts, factory torque specs, usually motor oil. ARP bolts, and ARP recommended torque, ARP lube. ARP recommends different specs in the bolts instruction sheet if you use motor oil.
What I ended up doing was I lubed up the rocker shaft pedestal's with a little motor oil, wiped the bolt with a rag and torqued to stock specs. I figured what little oil got into the pedestal hole would be good enough. What do you think ? Kyle.
Just tighten those until they feel right. With any luck you've got upgraded shafts or shaft supports.
With the stock setup you have a 'flat' clamping down a 'round' that happens to be hollow. I'm kinda amazed it works at all as you're using the rotational torque of a screw to hold down a squishy hollow tube that's full of harmonics. It's a recipe for disaster (that sometimes happens)
