Prototype Oil Pan?
It won't bolt up to a 109 block for sure,look at the pan rail where the gasket rides. It's way to curvey.
Probably a boat pan. It will NOT fit in a GN. The sump is located right were the cross member is. Maybe a prototype for a FWD application.:confused: Not a Busch pan either. They would at least have a kick-out on the R/H side of the block. Most circle track pans that I have dealt with/built were sheet metal and have a big sump on the R/H side of the engine. (go fast.........turn left........ The oil is glued to the R/H side of the block and pan.;) )
The sump is in the front...not the rear where the cross-over would be. What is the purpose of the vertical bosses (w/hole) on both sides at the rear? Could this be a Indy car pan or an Indy Light pan?
Conrad
The seller sent me this:
Dear cocarter1,
it came off a buick V6 turbo motor, it was part of a display that buick sent around to racetracks back in the 80's it came off a "street" race Grand National thats all i know about it
- tdearstine
