First I am wondering is there anyway to change it so that the VE table reads in PSI instead of KPA along the vertical axis?
If not is there anyway to convert KPA to PSI, I have an excel sheet I use to make mass changes to my fuel table. I actually developed it for my AEM EMS and it looks at a certain load which has a certain AFR defined for that load. If the load does not match it tells me how much to increase or decrease fuel for that RPM position.
The challenge I am facing is when I look at -psi, how does this convert on KPA? I can log PSI off of XFI but when i go to make fuel changes, I need it back to KPA, but I can't seemt to make sense of the conversion.
