- May 26, 2001
Welp, I've decided to take my own advice and am selling my recently installed PT6776S turbo. That advice is, "If you're gonna be a bear, be a Grizzly." I purchased this turbo from Fred (tbirdv6) about 4 weeks ago. When I got it, he said it had maybe 500 miles on it and was in perfect condition. I got it, installed it and it worked great after I installed a brand new PTE turbine housing and had the wastegate hole perfectly ported to match my Terry Houston downpipe puck. It came with a ceramic coated turbine housing that had the threads stripped out of one of the downpipe bolt holes and the wastegate hole was ported badly. (The puck would not seal/cover the hole completely.) So, I purchased a new PTE housing and had the hole properly ported. It worked flawlessly after that. No shaft play, no signs of oil, nothing. In excellent condition. I have put maybe 300 miles on it since I installed it. Only made a few street blasts and it works great. It did take out a new C6 Vette this past weekend on 20psi and 93 octane pump gas. And my motor is a stock 98k mile motor with only valve springs, a timing chain, 60#/TT chip/adj fuel regulator/HW 340 pump fuel system, PTE Stock Location, 3" THDP, dual 2 3/4" exhaust and a RJC Power Plate.
It will come with the correct CNC aluminum bracket that properly orientates the wastegate actuator. A Heavy Duty wastegate actuator will be included with the turbo. The turbine housing is a PTE .63 A/R THB3-76 and is only 3 weeks old. I will be taking the turbo off this weekend and will be able to get better pics of it once it's off the car. As for now, I only have two pics that Fred used and one I have of it installed on the car. Considering it has a brand new properly ported wastegate hole turbine housing, I would like to get $800.00 for it shipped UPS Ground anywhere inside the US 48 states.
This turbo spools up very good with my current 10" 3000 stall lock up and RJC boost control valve combo. It would be a tire blazer with an Art Carr 9" 3400-3500 stall and RJC boost valve.
Here are the pics that I currently have. The first two show the ceramic coated messed up turbine housing that came with it, which is not included. As said before, it now has a brand new turbine housing that's had the hole properly ported and the correct 3 studs which also did not come with it when I bought it.
And a pic I took this past weekend of it installed on the car.
I will post more pics later this weekend, probably Sunday. I will accept a Money Order or PayPal. Just add 4.9% if paying with CC via PayPal. (that's an extra $39.20, so PayPal amount would be $839.20)
PayPal address is prubioru2@sbcglobal.net
To keep it simple, please reply here or send me a Private Message if interested as I know how hard it can be to keep track of who gets first dibs on an item as popular as this turbo.
My only reason for selling is, I recently purchased a PT6776RHP from my buddy Don on Monday. Now's you're chance to get a great condition KILLER turbo for the street. Hurry as it won't last long.
Thanks for viewing.
Patrick
Thanks for viewing.
Patrick
