PTC converter #'s
ikle
Can anyone tell me what the numbers that are stamped on the converter translates too
the # is PTC 10-700-27LU S. Thanks
I'm taking guess but it probably means something along the lines of
PTC 10 (10" converter) - 700 (700r4) - 27LU (27 spline Lock up) s (probably indicates the stall)
looks like 10 700 27 spline lock up S means small bolt pattern
Per Dusty....
10 is the core of the converter. 700-27 is the designation for the turbo buick spline input shaft. LU is the lock-up, S is the 2800 stall.
**winner winner**
Dusty can you help me with this one? PTC 9-5-700-27-17-6?-? I can't read the last couple of digits on the box. the second to last looks like a 6 but it is smeared. I ordered this 9.5 NLU in the summer. So what does the 17 mean and the 6 (I think) Thanks.
Tony
Tony
The 9.5's are a different animal. They aren't spec'd for a low rpm stall #. They are spec'd for a hp level and shift point taking the entire combo into consideration. You will begin seeing boost around 3000-3200 rpm
