Pts 4th Gear Clutch Pack Kit????
PaulRV6
The stock setup uses 2 clutches and 3 steels (2 steels against each other). With this setup do I put the add'l clutch plate between the two steels?
paul
Yes,
You would use a normal clutch stackup, starting with a steel on the apply piston, then a friction, then another steel, friction, etc. Ending with a friction and then the pressure plate.
