Oct 3, 2004 #1 P PaulRV6 Active Member Joined May 25, 2001 Messages 1,677 The stock setup uses 2 clutches and 3 steels (2 steels against each other). With this setup do I put the add'l clutch plate between the two steels? paul
Oct 3, 2004 #2 J jakeshoe Member Joined Nov 19, 2002 Messages 986 Yes, You would use a normal clutch stackup, starting with a steel on the apply piston, then a friction, then another steel, friction, etc. Ending with a friction and then the pressure plate.
