tim87tr
Obsession or Digression?
- Sep 19, 2001
PTS shift kit install, a few more questions. The 4th accumulator spring is above the 2nd acc housing and this 4th spring replaces the stock orange one, right? This 2nd acc spring is shorter, and thicker, and would go case, piston, new shorter spring, plate, then 4th acc housing, right? A lot of this is in the instructions, but I was not 100% sure.
Also, for the check balls, I guess using vaseline to hold them (5 total) up into the proper holes is ok? Then 2 check balls would sit in the VB during the bolt-up. And from looking at the diagram, is 7 total check balls to be used the correct TOTAL final number?
Lastly, the hole marked "leave alone" does not need anything? I had one check ball that fell out I did not see where it belonged. It looks like there is something already up in that area, so just checking.
Thought of one last thing, want to do this job once
. Is it necessary to use any sealer/shellac on the plate and Accum gaskets?
Update...My son, age 9, just helped me put the check balls in under the car, he read the VB schematic well
