tim87tr
Obsession or Digression?
- Sep 19, 2001
Installing my PTS shift kit. I have installed the line bias valve spring and understand how the zinc retaining pins work. Question is for the TV shim and spring, how do I remove the retaining pin and plunger to install the parts?
There is a pin near the end of the plunger on the bottom of the valve body I tried to pull down on, but did not want to force. I also see another pin on the top/trans side of the valve body back toward the middle of the plunger route (I see the pins listed on the instruction sheet too). I thought maybe the plunger has to be pushed in or something to remove the pin, like the line bias pin, but was not sure and didn't want to break anything. Thanks
