PTS Transmission Pan?
LEGACY_GN
Through searching the consensus seems to be that this is the best one but I can't find a link to buy one anywhere? Can someone point me in the right direction. Greatly Appreciate it.
Doubt its available new anymore. CK sells a deep pan with rear sump system that is functionally the same.
Got my Hughes Deep Aluminum Transmission Pan from Nick Micale at Arizona GN. :)
Great transmission pan and Great Vendor! (y)
FYI.....Had it powder coated black before I installed it.
The hughes pan is not functionally identical. it uses a stock 700R4 filter which sucks from the middle of the pan, whereas most custom welded sheet metal pans have a pipe and a screen filter in the rear of the pan. Also there's the cast VS sheet metal construction.
I won't pretend to know the point at which the hughes could allow air into the sump, if its even possible when properly filled. But they are different designs.
Bruce has pretty much hung it up though he might have some stock left. You might give him a call and see. Otherwise the above suggested places would be your best bet.
