pump question
rob85gn
buick_lover
the plastic peice behind the pump was in peices in the pan when i pulled it off my question it should i replace it because the transmissin still worked ok untill i noticed this should i leave well enough alone or should i re place it thanks in advance:confused:
Fix it right or the transmission will not continue to work properly for very long.
