push rods to use with T@D 1.55 rockers
orangecar
Can I use the standard length push rods with these rockers,using standard deck height,.068 cometic gaskets, champion heads. thanks.
YOu really can only check them carefully. Are you running a roller cam? Flat tappet, Hydraulic? You MUST check the pre-load and geometry EVERYTIME to get it right. Small window of adjustment.
Call Full Throttle and ask for a adjustable push rod. It will give you the correct measurement. This is the only way to get your length right.:wink:
Then call Manton or Smith Bros & have a custom set made in 3 days.
We have an actual checker that is labeled so you can see how long it is, An adjustable push rod alone will not do it unless you have a special fixture to measure them. Pushrods are not measured end to end because of the oil holes but on the 120* down radius. Our tool starts at 7.800 and goes up .050 for ever full turn. I can then get you pushrods in one day 98% of the time. If a customer buys a roller cam kit from us he can opt to buy the tool and tell us what size pushrods he wants which we will ship later at the kit price
Mike
