Quarter window gap on top.
czimpel
Boost...gotta get some!
Both side of my GN have gaps at the top of the quarter windows between the rubber seal and the body. I've pulled the interior trim piece out to see if there was some adjustment, but I couldn't seem to find anything. Is there a cure for this?
There are studs with nuts on them, They might be missing the nuts. There just cheap nuts. Check that first, otherwise you need to pull the windows and clean the old sealent off and reseal the window again. They will push out with all the nuts off. I think there is 6 of them.
Thanks, I'll give that a try.
What type of sealant do I need to get? Will windshield sealant work?
Yes,O'rielly auto parts carries it in the tube for a culk gun for $22.00 behind the counter, not out front in the store. Just try to tighten the nuts first but to be safe you might want to reseal them because it may still leak if you don't.
Also at the same parts store you can get a roll of butyl rubber which is what they were installed with originally and it works great. 1/4 inch i think.
