I just ordered a coil and understand that it comes with a gasket for between the coil and module. I also understand that one side of the gasket has adhesive and is placed on the module side.
My question is, since I am only changing the coil, is it necessary to replace the gasket the on the module, or would it be best to change it ?
Second question, is it necessary to either disconnect the battery while changing and is it necessary to reset the ECM ?
Thank you
Trying to learn
Thank you
Trying to learn
