question about grounds
LTNG KLLR
I was wondering if it was all right to put the all 4 grounds with the same bolt, the one that goes to the head, if not could you put the 2 longer ones on the firewall somewhere?
Yes...that is how the TTA's are done...last bolt on the intake manifold passenger side.
Kev :)
yes you can put all 4 together? or yes i can put the 2 longer ones on the firewall?
Sorry for the missunderstanding
Yes you can put all 4 grounds together. I recommend putting them on the 2nd to last intake manifold bolt on the passenger side.
Originally posted by LTNG KLLR
I was wondering if it was all right to put the all 4 grounds with the same bolt, the one that goes to the head, if not could you put the 2 longer ones on the firewall somewhere? Thanks
Would not think it is good to mount 2 of these grounds on the firewall. They are supposed to be on the engine. The battery grounds to the engine so the engine harnesss grounds should be there too.
A good idea to run another ground from the firewall to the engine, as well as from the frame to the engine.
