Stock settings= turn on approx. 4 lbs. and 11:30 on the other dial in the hard box.
This setting would turn on at 4 lbs. of boost and max out at 30 lbs. of boost with the 3 bar m.a.p. sensor.
My question is where would you set the blue gain knob to get this? i.e. 1/2 way, 3/4 way, etc. and if say it would take a 12 o'clock setting with the blue gain knob (control setting flat on top of center pod) what would just turned on (blue knob) or full tilt give you? ( full output by 24 psi )
Devil's own controller does not have an on/off switch or a purge button but the start setting comes on with 15% than ramps up to 100% at the full on set, i.e. say on at 4 lbs. and say 100% at 20 lbs. or 30 lbs. etc. This is what I got from reading their ad. I am trying to get some sort of standard.
