Question For The Board
my85buick
im building a 383 chevy stroker for my 85 buick,ive been told that a 7.5 eaton posi with moser axles would be plenty strong enough to use and would not break......any input or advice would be helpful
my advice is to put this in the general auestion section, not the parts for sale section. :biggrin:
buickbert
I've got some new moser axles for a 7.5 inch rear if you haven't bought them yet.
buickbert
He's right.... but I wouldn't waste any money on the 7-1/2" .... while some people have gone fast with it.... it is definately the exception.. not the rule. Just a few aftermarket goodies... and you could buy stock 8-1/2" rear end that will take quite a bit of abuse... in stock form... just my 0.02
If you didn't put any sticky tires on it however...... it might hold up for awhile....
I had an 83 Regal that I built a 385 Stroker for... I even had too hot of a cam with too small of heads. I used a 280 Magnum cam with the 1.94/1.50 iron heads. I topped it off with a carter 650. It ran OK, but it seemed like the heads ran out before the cam really started pulling. It did have monster torque off the line. First I broke the 7.5 open rear with the 2.x gears. I found for $75 a 7.5 rear with 3.42 gears that was posi. Broke that one too. Before I sold the car, I had rebuilt it with 3.23 gears and the Auburn posi carrier. It seemed to be better, but I never pushed it.
The best the car ran was a 14.1 @ 94 on the 3.42 gears, so that tells you I really wasnt making a lot of power...
If you are going to build it right (and not on the cheap like me), that 7.5 won't last, unless you really baby it.
I never ran slicks. Mine always broke at the same point, the 1-2 shift. Car would shift, and I would hear marble noises and come to a halt. I always scattered the spider gears inside the carrier - and those would invariably take out the ring and pinion... :(
Just find an 8.5 and be done with it.
I would say ou can use yor setup but when it breaks on the next go around Buy a bigger rear end.
now here is food for thought. In my 1981 regal w SBC for a whole summer/fall I had a 4:11 in a stock 7.5 rear. I raced that puppy on the sreet/ drags/ & oval Drags. It never broke under all that abuse!
