Question for those running an AVC GNX style dash
1KWIKSIX
Question for hose running this set up.
Since removing the factory dash & installing the AVC dash , the small dash bulb that the factory used to excite the alternator is no longer.
Are you having issues with the alternator not charging & resulting in low battery voltage or does the AVC wiring harness accomodate this by using a resistor in line somewhere?
Just curious .
Dave
Not sure on the dash but the casper field fix setup is just as easy and will fix it.
