SignUp Now!Oh, there are two "t's" ? The instructions only talk about one "T". It doesn't even mention the other line off the reservoir that goes to the PS Pump. I may be headed to the Volo show July 7. Are you sure there are two t's? I think you pm'd me your phone # once but can you give it to me again? Is the HB installed on your car or is it for a customer? Just want to know if I can look at it, maybe take notes and pics. Thanks Rick.Yes, the two return lines are T'd. The ss braided are the feeds. No T's.
The line off the psp has a 90*. When the pump is mounted the 90* faces toward the passenger side. The line then comes down around the bottom of the psp and over to the wheel and up the the hbs.
Let me know when your in town. You more than welcome to stop by.
Rick
The fittings on the 85 lines don't screw into the Hydratech unit. Haven't tried yet to see if they screw into the power steering pump or the gear box.TexasT posted some very nice pictures of his install on another thread when I asked him how he got the hoses connected. You can use the lines from the 84/85 set up. Got mine from rock auto for a little more than $40 for the pair. The only "mod" is you have to bend the line that attaches to the power steering pump just a bit to get it to line up correctly. The braided lines look great and are the way to go if the budget allows...
I think the ones sold by the parts stores are Cardone rebuilt units. I've had bad luck with Cardone and don't want to trust my brakes to them. Will be selling my Powermaster (Cardone rebuilt) if anyone is interested. The Hydratech is $540, expensive I know but it is supposed to work quite well. They package some braided hoses ($200!) with aroequip fittings. I don't know why they didn't match up the GN fittings, unless this is a G-body unit and other g-bodys use different fittings. Also, this unit has a back up vacuum reserve in case the engine or power steering pump craps out. The original 85 unit did not have this, unsure about the Astro Van unit. So with engine failure the brakes go south too. Could be overkill, but did I really need Cotton's front mount on a mid 11 sec. car?What does the hydratech unit come from? I wonder why they wouldn't have it use the same fittings. If you don't mind me asking how much was this unit? What made you go that direction? Just curious as the factory stuff is very reliable and easily replaced if the need arises. TIA
