turborambler
- Feb 10, 2005
2 questions on a install:
1. The wire that comes from the FAST system and goes to the wire I cut on the fuel Inj. harness - should the wire from the FAST harness be a red wire with a black stripe maybe?
2. I spliced in the wire from the middle wire of the MAF harness to the middle wire on the 3 bar MAP sensor. Should I cut or splice into the middle wire on the MAP sensor? I spliced it but then I wonder if I should not just only have a complete curcuit from MAF to MAP and nothing else. I am guessing the FAST system will get the signal from the old MAF sensor harness.
I hope I am not too confusing on this.
Thanks for any help.
RossJ
RossJ
