got my new motor running . was running great then
i developed a sort of a miss on cyl #6.
have spark at coil. when u unplug the injector car doesnt change rpm at all.
checked cyl #6 with a temp gun and it runs at 210* at idle and goes to 260* at 2k rpm. all the rest are around 450-500*
pulled plug and replaced with a new one. gapped at .035 still runs the same
tried different chip. no change
checked spark at coil good spark.
has new tt chip and 60lb delphi injectors
no abnormal engine noises heard. revs good. oil pressure 20lbs hot 65lbs cold.
eng temp is at 175*
no codes being thrown.
scanmaster values seem to be normal. i had a vac leak at the egr but fixed it.
going to try new wires and swap injector around.
any ideas?
thanks for any help.
eng temp is at 175*
any ideas?
