Buick Beginner
Where is my $$$ going?
- Nov 9, 2001
Gentlemen,
I notice that I can't seem to hold more than 2 or 3 lbs of boost on the line, I've already got the Kirban soft shoes but I don't have the S-10 wheel cylinders yet, I guess they will help. Anyway I've read a number of articles that say the more boost you can hold the better. Now, with this in mind I've noticed the following: If I take it up to 2 lbs of boost and release the brake I can immediately feel the jerking forward and so I punch the gas WOT. About 1 second after the punch the rear tires go up in smoke. Now, if I build 2 lbs and then release the brake I can immediately feel the jerking forward and then EASE into the throttle mashing it to WOT over a period of 2 or 3 seconds the tires don't come loose. So, now with that in mind is the following information correct? If I can hold say 10 lbs on the line I will have a harder initial launch, (the car lunging forward), but then I will still have to EASE into WOT to keep the tires hooked to the pavement? Or is there something magical that happens by launching at 10 lbs where I can immediately floor it with no tire spin? My suspension is set up pretty good as you can see on my signature but I want to make sure my launches are the best they can be. Thanks - BB
