Exactly. The fewer the rows and bigger the tubes the better it dissipates heat. Maybe NY Twin Turbo will share his pictures of his when he boxed in his rad. Did a beautiful job with it. Actually what's not perfect about his car.
The Cold Case,which is also sold buy Kirbin's, and the Alradco are both radiators that utilize 2 rows of 1" wide cooling tubes. There's nothing better except a core with 1 row of 2 " wide cooling tubes,but that would be a very expensive custom made radiator. This is what they use in NASCAR. You can't produce copper tubes this wide because copper lacks the strength and the tubes would collapse.
Just noticed my name was mentioned. Thank you for the invitation.
I'll share what I have done. But once again, I'm afraid the things that I have done to my ride are not often applicable to most other TRs. Mostly overkill to the extreme, my mods were made in an effort to build a twin turbo car that can be driven for any amount of time, in NYC traffic or on long highway trips on the very hottest days of the year. Sometimes, I wish I could be more help.
-I don't have an AC.
-I don't have internal oil or transmission coolers in my radiator. I do have them both and both are on fans, but they are external.
-I don't have heat (not a factor, but it minimizes complexity in the engine compartment.)
-I don't have any coolant bypass tubes on the intake manifold.
-I do have a large custom built
46 row wide, bar and plate, 3-1/2 inch thick, top fed to bottom tank, twin turbo configured intercooler.
-My 160 degree thermostat has three 1/8th holes drilled in it at the 12, 4 and 8 o'clock positions.
-I use standard Prestone mixed 50/50 myself with distilled water and a bottle of RMI-25.
-I flush the coolant and replace every other driving season (2 years).
-I have an electric Mezier water pump on a manual switch. I leave it on all the time. I'm in the habit of using the master disconnect
when I get out of the car. (no radio or clock to reprogram
-I use a cut and trimmed stock style silicone lower radiator hose, and a custom aluminum upper radiator pipe with silicone couplers.
-I use the dual Intrepid fan set-up (Ram Chargers, back when I bought it). Manual override switch and XFI controlled
169-on 164-off , high speed only operation.
And the two things described by others in this thread in the posts above.....................
-I have a Tony DeQuick radiator. This is an aluminum dual 1 inch core radiator as described above by Ttype6.
-I have my entire grill opening baffled tight as a drum so that absolutely no air can escape travel through the interccoler and then must go through the radiator.
See photos below.
