Question on stock turbo dimensions
JL8Jeff
I don't have a turbo Buick, but I'm looking at using the Buick style turbo on my 68 LT1 Camaro. I was wondering what the dimensions are of the turbine mounting 3 bolt flange(center of bolt to bolt). And what size is the opening(2-1/2" or 3")? Also, are the PTE turbine housings the same 3 bolt pattern as stock? Thanks,
Jeff.
Does anybody have a turbo sitting around they can measure? Is it a 3" opening with the bolts centered each 3-1/2" apart? Is it a 2-1/2" opening with the bolts 3-1/2" apart? Any help is appreciated. Thanks.
Anybody? Does anyone have an old turbo mounting gasket laying around that they could measure? Thanks.
The exhaust inlet hole diameter on the stock turbo with the garrett housing is 2 1/8, and the center to center on the studs is 3 1/16. The PTE housing has the same center to center on studs and it may have a slightly larger inlet diameter.
Greg
