turbov6joe
Signal 1 J-12
- May 22, 2002
Is there such as thing as having too many tranny coolers creating too much pressure loss, or is this something not to be concerned with? What I have in mind is running yet an additional B&M stacked plate design cooler in conjunction with the TTA radiator cooler. Once I switch to a higher stall converter, I want to keep those temps in check with the T brake. I'm affraid that the single cooler with the OE cooler might not be enough because of the lack of air the TTA's have going across the front of the radiator and external cooler. I remember some time ago someone posting that using 3 coolers might create a pressure drop???
