question?
nomad
So today i did the "f-body" rad in my gn,also installed a external trans cooler,now for the oil cooler,i removed the 2 lines by the oil filter and just installed 2 brass plugs,
-is it ok to do this?
-or should i just get the oil filter adaptor that just bolts to the block?
:confused: :confused: :confused: :confused: :confused: :confused: :confused:
im not positive on this but i beleive blocking off those lines will block off the return oil supply to the block and your engine will fail in a very short time .
if you arent going to run a cooler take the cooler adapter off
just screw the fiter back on
