G
GRAYGHOST
Guest
For those of you who have gone to a stage II set-up, if you had it to do over again, or looking back, what would you do different?
I have a Turbo T that I am thinking of doing stage style over the next winter.
What areas do you concentrate on more than others? Any stuff you would buy new, and other stuff you get by with used?
I plan on getting the suspension set-up thru the summer with what I have, the trans is a PMAC built, will it hold? I know I will have to bump up the converter.
I don't plan on going with anything huge, I was wanting to have it set-up for easy low 10's, then if turned up hit mid 9's. Something like what, a PT-72, 96# inj's. Definetly a F.A.S.T. system, an SX pump, is a sump tank necesary? What size AN lines to the rail?
Any info is appreciated trying to spend once on this car.....Which gives me my last question, realistically, what will I end up spending when all said and done, if I can hopefully get some deals?
