L
Lugnut
Guest
My car ran fine and then it began to shift from first to second and bog down. At normal driving you start off it stays in first for about 2 seconds and then shift into second and bogs down bad, then you give it some gas and it up shifts and is fine. Also when you come to a stop it shudders like if you had the clutch out on a manual shift and then sometime it even stalls. I had the transmission taken apart and the insides were fine. The guy who took it apart said it must be the torque converter, I changed it but still have the problem
