Flyin Brian
- Jun 18, 2011
I have done a ton of searching and reading on here on the topic of what valve spring and seat pressure to run with a Comp Cams 218/212 hydraulic roller cam and 1.65 roller rockers on ported stock iron heads.
General consensus seems to be Comp 941 or PAC 1201 at a seat pressure in the range of 140 to 160 lb.
My max valve lift is .545. I have the heads off and apart at the machine shop now and I discovered that my seat pressure was 95 lb at 1.76 installed height. I thought I had K-Motion 750 springs so I had them check them at 1.7 expecting to see close to 130 lb but it was more like 110. So, either my 750's are real tired or they are actually 700's. In either case I need new springs. Height from head to underside of retainer is 1.8.
Quick question 1. Which of the above springs and what seat pressure?
Quick question 2. In either case should I shim the required amount (.05" or more) or do I need different retainers so I can use less shims? I am planning on using my existing retainers if possible but will buy different ones if that is the smart thing to do to avoid a tall shim stack.
