Im running a T70,Art Carr 9 inch 3800 stahl,full weight car,looking for a faster spooling turbo that will run just as good up top as my T70,was thinking of switching to GTQ 70 thinking it will spool quicker? any advice would be greatly appreciated
SignUp Now!Originally posted by Cheeseburger
The q trim wheels do not spool as fast as the p trim wheel but are capable of making more top end power.
Imo the gtq will not spool quicker.
Play around with your programing if you are running dfi or get your chip reprogrammed with less low end fuel and it should help
your spool up.
Another option is to downsize your turbine housing (to .63) if you are running an 82 or 85.![]()
Originally posted by live2race
do you think switching to a 63 housing will hurt the top speed a sufficient amount?
I do not think it will hurt you at all, i am running a 63 on my turbo and have plenty of top end.
I agree with you that your car has plenty of top end,but im only running a 70 trim compared to your 76,my car trapped 130 mph with a 4 inch dump & Hooker headers,now I have stock headers & a single shot 3 inch exhaust![]()
Originally posted by Louie L.
Another option is to go with a ball bearing unit which will help tremendously but its not cheap.
Originally posted by Ted A.
The 70 GTQ is capable of blowing up a stock block no doubt. I would just buy the .63 and .85 housing(s) from the get go if I was you if you are worried. My opinion is your stall is more than enough to get it on-line. Yes, the GTQ wheel is a little tougher to spin up, it is heavy.
