Quikee Turbo Regal Contest(s)
Oh, Least.
Engine block heater.
No, wait. Is it most common, or least ?
Most common?
Heavy duty battery.
kirban update
this contest is still looking for the answer to match mine engine block heater is a good guess but not as rare mostly cars that have it its overlooked if its still factory wire tied on the left side up front....
Plus in Minnesota I am pretty sure it was a popular option.....seems one town in Minnesota ranks the coldest every year.
denniskirban@yahoo.com
BINGO
We do have a correct answer post 283 which just popped up while I was typing my answer....fixed column when can any readers recall seeing a fixed column in a turbo Regal....
Same rule winner this time has to step back on the next contest.
@LIVE4RDO removes tilt in his cars and installs fixed columns from what I remember reading
Not sure how to word this next contest so it makes sense without giving away the answer.
Here goes:
Again focused on a stock new 1986 or 1987 Turbo Regal. There is an option you could pass on (delete) which got you a few bucks but at the same time you could buy this other related option which on the face of it made no sense.
What am I referring to?
To answer the question as to what is the code for a fixed steering column. We need someone reading this to respond who has it. It wil be a N code as N34 is the sport wheel N35 is a tilt column so it will start with a N.
Since it is not an option it doesn't show up in my options booklet and in the Production book I can't ID it either. Point being I don't know everything!
My car has a tilt.
BINGO
POST 290 however he is only partially correct if you read my clue the weird option would be ordering was a power antenna and a radio delete...I actually had at least 2 cars with window stickers that verified radio delete and had code for power antennas...
moving along...next contest.
Astro roof key,spare keys
Sent from my SM-G920T using Tapatalk
I'm confused or I am totally misunderstanding your "clues".
In your last post you say this particular "option" was the LEAST chosen you've ever seen, 2 or 3 cars, yet in your original query, you say it was an "option" on 90% of the TR's you bought and sold.
How does that work?
How does that work?
I clarified it later in another post. Had a loong day today.
BINGO
Post 296 nailed the correct two answers spare keys I guess would also work however I am not sure if that was standard the front license plate bracket usually was in the trunk. The optional hand crank for the astroroof option was in the glove box with a sheet of directions.
Same rules this past winner has to sit out the next contest.
Hope this contest last til tomorrow
Reminds me when I was in the Army after my year in Vietnam....I got great duty as instructor/teacher at the Induction Center in Philadelphia...giving tests to incoming draftees etc.......
Here goes:
You bought a 1986 or 1987 Turbo Regal in the last dozen years....one cap is most than likely missing from its location under the hood.
What cap am I referring to.
Member answer has to match mine. I base this on cars that passed thru my hands.
radiator?
I asked about the tilt column because my 86 should have had a straight column (no code ) but has a tilt. Your trivia put me on to it. Thanks Mr. Kirban
