Qustion
scpls19398
Hot Air Fan
Good morning all, I had an engine built, only has a few dyno pulls on it, want to make a cam change from a flat tappet to a roller, Do i have to replace the cam bearings or would they be ok?
Ive reused my cam bearings 3 times now. After a couple of blown headgaskets everything looked ok so I just reused over again.
should be fine if they look good but if the engine is out of the car it will be vary easy to pop some new ones in IF NEEDED
