The Darkside
Heavy Metal Thunder
- May 25, 2001
Look at my sig below for my combination and then please try and help me figure out what went wrong!!!
By the way,I was on some really worn out drag radials(18psi) tonight.
My 1st run #'s: boost was 23,fuel pressure 39 line off,alchy was set to come on at 15lbs,pump speed was at 1 o'clock position.Car popped a little at the top of 2nd gear,6o ft was sad 2.04 Results:8.47 @ 82mph
2nd run:everything the same except turned alchy up to 5 o'clock position,results:same with car bogging at the top of 2nd
I am really confused at to why I got these sad results with the combo I'm running.I mean that is only around a 13.1 in the 1/4.Heck,I ran 13.3 3 years ago on street tires and my only mods were a chip,k&n & walbro fuel pump!!!I wasn't able to use a scan tool tonight,but with all the setting the same as in my 1st run and using a scan tool a week or so ago while out just running around on the street,o2's were 850 coming down to 790 at the top of 3rd gear,so I thought they were fine,I would love some suggestions from you guys on where to start looking for the problem.I mean I must be missing something big,because I fully expcted to run 7's tonight.
The Darkside![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
The Darkside
