TURBOTWIN2
ASE CMAT L1
- Jun 17, 2005
Got my Walbro 340 fuel pump kit with the hot wire. Good looking stuff. Came with no instructions, same as a couple of other guys here have said, but looking at their excellent photos on the website, I was able to figure it out. I installed it and NO FUEL PRESSURE. Verified hot and ground at the connector and sufficient fuel quantity. Had to pull the tank back down to troubleshoot. What I found was that the hot wire (red) that plugs into the connector on the bottom side of the unit was in the spot for the fuel sender (purple wire). I didn't check that it was in the right hole, it looked correct with a quick glance and I transferred the purple sender wire into the other hole. I also didn't check to see if the pump pumped before installation or pressure and volume test, nor resistance of the windings on the pump or run a current ramp test on the pump or check the micron capabilities of the screen BECAUSE I SHOULDN'T HAVE TO DO ANY OF THAT! I really enjoyed doing the job twice. With over twenty years as a certified professional auto technician, I don't need any practice. Thanks. Vent over.
