Looking for some expert opinions on rad construction
Because of space limitations (Hybrid) my rad has to be small. I am looking for ways to max the efficiency of what I can make, given the size limitations. Also I am limited to copper/brass, because of the unavailibility of a aluminum core in the size I need. So...
If I have a a maximum core width of 2 1/2" how many rows of 5/8" tubes can I use? (I am also limited to a 2 3/4" x 2" tank)
Fin count. If I have airflow limitations because of the small overall core area and a tight engine compartment airflow wise, which will work better, a high fin/inch count, or a low one?
BTW I have a 3 core 1/2 tube setup in there now, and run RMI-25, a Flowcooler water pump, overdrive pulley, and a Ford Taurus 2 spd fan.
Thanks,
Paul
Thanks,
Paul
