Radiator / Fan parts needed
TrAb
BOOSTIN
Hey guys i need a radiator that is in good shape, and i also need the sensor that goes on the front of the fan. Not sure what this sensor is called but it almost looks like its made out of a ceramic material. I have a picture of mine that is broken if you can see it. PM me thanks
and is that screw touching the uppipe ?
when the fans are commanded that screw has 12v , looks like its in contact with the uppipe if so so it as well as anything in contact with it like alky lines or chrome maf tube... that's a short circuit waiting to happen ...all it needs is to touch a ground to complete the flow and its a dead short and there is no fuse on that wire so it could have already burned up the fusible link .
Yes it has touched the uppipe, so im sure it popped a fuse already. Just need to replace it i believe.
that pipe isnt in direct contact with any metal due to the hoses so it may not have blown , if it did its not as simple as a fuse , the fusible link is down by the starter and it would need to be cut out and a new section of fusible link installed (solder and heat shrink is prefrred but crimp on butt connectors wil do if you seal the ends of the connectors from the elements )
Yeah i hope it didnt do all that, problem im having is my fans are not cutting on until i turn the car off. Then the fan makes it run for the 10mins for cooldown.
Looking for a perfect one really. If somebody has one I've got money, just didn't wanna spend the 400 there asking for them on ebay
