Radiator fan wiring?
missin' 2
What wire/pin is the fan trigger wire on the ecu?
That is what I would use to trigger the fan relay when ecu turns fan on? Just double checking.
Thanks for the reply
It is pin D2 at the ECM connector. Ground it to run the fan on low speed.
RemoveBeforeFlight
Key-on, engine-off. Grounding that terminal activates the low speed fan relay.
RemoveBeforeFlight
Ok, the fan works by grounding the d2 connection.....so now I know the fan is good and works. It does not come on when the car gets up to temp, so what should I replace or check next?
Ahh, I found it. The plug terminals for the delay relay were smash. I guess some tried really hard to plug it in and smashed the shit out of it trying so hard?
The delay relay won't case this issue, best to unplug it and leave it in the trunk.
Since the fan runs with terminal D2 grounded, that leaves the ECM. Using a scan tool of some sort it would be best to first check that the ECM is reading the CTS (coolant temperature sensor) correctly. As the connector corrodes the ECM sees that as a lower coolant temperature then the actual temperature.
If the CTS reading is OK, then the likely problem is that the quad-driver in the ECM is bad.
RemoveBeforeFlight
