Radiator support bushings...Help!!!!
v6turbojunkie
I don't know how they go back on the car. My old ones were so rotten when I took it apart you couldn't tell how it was supposed to go together. A detailed explanation would help.
Thanks.
The fatter part of the bushing goes in underneath through the frame rail and the smaller part, which fits over it, goes on from the top. Both top and bottom bushing should have large washers which the nut and bolt tighten against. Install the bolt through the bottom and the nut on top. ;)
