radiator support pads
MNwe4
I realize that there's supposed to be 2 pads that the radiator sits on and 2 that go on top that the plate presses down on. Unfortunately my car doesn't have them and I'd like to correct the situation. I do have a larger aftermarket aluminum radiator.
Are these pads unique to our cars and does anyone have an idea where I can find them? Unless I'm not using the right keyword I haven't found them on Highwaystars, Kirban, or Gbody.
Should I just use a rubber/foam piece of some sort instead?
Thanks guys, I see tons online like the ones in the summitracing link. Didn't know if there was a special one that fits nicely into the top hold down plate. If a standard piece of rubber will work then that's probably what I'll do instead of trying to find the perfect molded piece to fit.
