Radio Hotwire not hot?
Old_Man_HyPsi87
Okay...so I am having a hard time on this one...I jumped a hotwire from the battery to make the radio work and it did work...also all the interior lights started to work, so I have a wire problem somewhere. I checked all the fuses and they are all good, no burnt anything and some stuff under there not original, alkycontrol mostly...
I need a wiring diagram can anyone help me out with this?
The radio hot wire is the orange 12v wire.
If you are not getting 12v than the fuse has blown. Just try to check the cig fuse.
the fuse in question is at the very top and the hardest one to get to:rolleyes: should be a twenty amp (yellow),no larger.
If it is that easy I will be severely disappointed:mad: But dumber things have been overlooked before, so I will check it out and let you know:confused:
Problem Solved....
:rolleyes: I thought YOU checked ALL the fuses.I think I am starting to get old and uh...uh...OH Yeah! And forgetful;) thanks guys...I learn something new everyday...LOL !!! I nominate myself for the "DIPS#IT" award!
Anyway...on to the next issue!!!:cool:
