Random parts needed PLEASE!!!
sdteb
trying to get it like you
Detent bracket on the doghouse that the throttle cable goes to
one power steering bolt,
the pipe thread to -AN adapter for the stainless coolant line from the gbody parts on the intake,
motor mount bolts the ones that go on the frame mounts to motor mounts
on the ac bracket theres a treaded stud that the AC slides on and a nut goes on the end
also need the valve for the shrader valve on the fuel line
plus the coil bracket the one on the back U shaped
stock vacuum lines going to the vacumm block on the tb.
Please help with these.
I pay cash, paypal check, money order..
I need these to finish the car sitting at a friends house :(
Thanks in advance ;)
Vacumm lines - is it the set of 3 lines from the vacuum block you are talking about? <- I have...
We have new now in stainless & factory used.
GBodyParts.com Online
plenty $1.00
Should be factory but we have that as well
$2.00
$7.00 with nut
Plenty new in stock $1.00
$20.00
Sounds like you have this handles.
Thanks in advance
yes i do...i have the vacuum lines (set of 3) and coil bracket...the rest i need...
