My 84 Randomly will start to run rough, die, check engine light on, won't idle, but does start after it dies but you must hold your foot on the gas a bit.
The weird part is, if you shut it totally off (ignition), sit for 10 seconds and restart things are normal again. No CEL even.
It will also hesitate every once in awhile while driving also but doesn't go into the check engine stuff.
Car has been sitting for 4 yrs, enging that is in it for 8 but has been running for about 3 weeks now, and 700 miles.
When it runs good, it will lay some nasty patches, cruise down freeway, runs and drives great otherwise.
I have diacom for my typhoon stuff, but have not been successful yet in getting it to link properly to check things out.
I plan to upgrade to 86/87 ECM in near future anyways.
Does it sound like a wiring issue?
Bad fuel pump?
Dirty injectors?
Ghosts?
Bad fuel pump?
Dirty injectors?
Ghosts?
