SignUp Now!Lifters possibly bleeding down while the car sits not running. Causing a slight rattle at start-up, but goes away with oil pressure/volume.
K.
I use K&N 3001 oil filter on my VW bug so that made me wonder. Is there a K&N for an '87 TR? Would it have the drain-back feature? I really like the filter they make...
Edit... I guess they do. This looks to be it. I am getting one. Here is the link.
HP-1001 - K&N Oil Filters, Oil Filter
kirban 2 cents worth
I agree with the above and anti drain back feature is a must, however if you are using sm oil regardless of a flat tappet set up or roller set up be sure to add zddplus which contains the necessary amounts of zddp a proven lubricant for 60 plus years. It may not quiet it completely at start up but will surely reduce it.
Remember when your car was new SF oil had about 1800 ppm of ZDDP and todays oils have between 600-800 ppm.
Product is available from most vendors on this forum.
kirbanperformance.com
denniskirban@yahoo.com
OK I'll bite, How will ZDDP plus reduce a lifter rattle on startup.
Got the same thing. I was just guessing that I am low on oil, quantity wise. It is due for an oil change so I may try a tad bit thicker type. Maybe the lifters are bleeding down???
